Was Luan not a Shorea species; perhaps Acuminata? Used to use it for lightweight internal lute moulds / formers.
Sam how wide is the door in the picture only looks about 27" or is it an optical illusion
Some you could have sworn was balsa whereas the heavier stuff sometimes appeared purplish and looked quite good.I am sure it will be Meranti, fitted loads on the 70s. They will be quite light unlike Sapele which is much heavier. We used to call it pink Balsa.
Seller has told me they're mahogany
If its all hardwood no soft pieces i would think too heavy for modern internal door frames certainly too heavy for mdf frames . Victorian frames will take it altho style is georgian
Take care with long screws the nearer two screws to the crank if they go through frame they could crack plasterboard/plaster behind architrave ,it wont show unless it causes a crack to travel outwards and with those doors defo 3 hinges
