Yes, I suspected some sort of drilling operation tooAfter some consideration and research I think its for making holes in something![]()
Almost. The larger diameter is clearance for the screw head. The smaller diameter is clearance (ish) for the threaded part of the screw.It is indeed a stepped pocket hole drill bit. The smaller point drills a hole the correct diameter for the screwthreads to bite into and the larger portion a hole large enough for the shank to slide into without binding.
