What fixings for kitchen wall cupboards?
stuckinthemud
17 Jun 2019
Caerphilly
Just picked up a second hand kitchen wall cupboard 300 by 1200 by 750. chipboard, from that Swedish flat pack company. It has 3 fixing points, is very heavy and will be carrying a lot of weight (it is going in the kitchen). I have the little height adjusters you fix through but no idea what screws to use. I’m fixing through black mortar to a stone and mortar wall. Any suggestions?
I’d be looking at kitchen cabinet brackets as they are fully adjustable in/out up and down . Pre fit the kitchen corner brackets to bottom corners of your unit prior to fixing it to the wall and drill through the main fixing hole through ghe cabinet back panel . Once you have hung it on the wall and levelled it etc you can drill through the lower brackets you fitted into the wall for additional strength
Hardware Solutions Nylon Cabinet Brackets with Mounting Plate 10 Pack (91611)
£10.99
Screwfix.com
(82)
Cabinet · Brackets
By Klarna
Cabinet Hanger Set Traser 6 Concealed Rapid Fitting Cover Caps & Wall Plates
£5.99
+£1.80 delivery
Handle & Home
30-day returns
Cabinet
Hafele 10 Pack Corner Gussets Zinc-Plated 65mm x 65mm x 19mm (9861P)
£4.00
Screwfix.com
(18)
Corner
You can buy the mounting plate in a long length, which makes finding studs easy / allows more fixing in dodgy walks / for heavy units.
I agree with Deema, continous lengths of steel hanging rail are the way to go. I had to use them in my kitchen, so as to avoid electric cable drops, which always seemed to be where a bracket needed to go.
