There's been a slight issue after floors been screeded and now I'm only finding out the door height is 2120mm high and width is 890mm
Can anyone recommend on what to do. If it put an 18mm thick flooring, 3mm underlay and a 2032mm(80inch) high door with a 5mm gap under the door and a 30 frame, I'm left with 2088 mm. This will leave a gap of 32mm! Is there anything can be done about this to close it off!
The width of the door, if it's 812mm(32inch) plus the both sides of frame is 30+30 now leaves me with 18mm on one side of the frame.
Does anyone have any advice on how to get around this.
