Just to be bl**dy awkward I have two. A Mafell LNF19 (earlier version of the current
LNF20) This is very similar to the AEG/Atlas-Copco - Mafell makes the front end for AEG/Atlas.
Why the Mafell? Apart from the fact that it's really well made and finished. it's one of the very few biscuit jointers with a turret depth stop like a plunge router. This means that the thickness setting can be preset for a project where you are using/jointing say 12, 18 and 25mm thick materials and changing thicknesses is then just a case of loosening the plate, flipping the stop round then resetting and tightening again. Can't think of anyone else's machine that does that.
The other machine is an old Elu DS140 (not called a deWalt
DW685). An offbeat machine but good in its own right. One of the few biscuit jointers you can use to saw a groove for hardboard (3.2mm) backs - the fence means it works like a saw. That also means that you can biscuit joint up to about 4in in from the edge of a piece (also unique). It's last trick is the ability it has to be used instead of a flooring saw when installing laminate floor - it has the ability to cut shadow joints in skirtings, etc. It hasn't got the depth of a true flooring saw, but have you ween the price of one of those. The main limiting pactor is that it's not as good for mitred corners. But who does many of those? (and there are other techniques for that)
I'd keep away from cheap ones. They don't last and aren't accurate.
Sorry, but I don't like the P-C, either. I reckon the opening ion the front is a bit big for some of the work I do. I also reckon the deWalt DW682 has a flimsy fence that seems to rack on some of the ones I've seen
Now I've displayed my bias, I'll get my coat.... :lol:
Scrit
