Woodwork Journey Dean
I picked up a second hand Erbauer ER2100 to go into a router table today. Noob issue and didn’t get the chap to plug it in. It may or may not have worked at this point.
I stripped it in order to make an above table lift. In the process the bushes came out and broke, but so did this what I believe may be a ferrite ring magnet that sits at the top of the motor column
It broke in two, and while trying to see if 2 part epoxy would stick it back together, I properly broke it.
The reason I was unsure if it worked when I picked it up is because of the burning where the bushes go in the plastic housing
Anyway, I’ve ordered some brushes that will hopefully fit, but I’m assuming the broken ring thing needs replacement, even though I have no idea what it does.
Will it run without it?
Any idea where I could find the possibly ferrite ring thing? Google gives me nothing close to the size.
I’m in the lookout for a broken ER1200 to scrounge for parts.
But this is how it looked to begin with, seemingly hardly touched!
