Wet room
joncooper27
UKW Supporter
26 Aug 2022
I am in the process of doing a wet room and decided to install the wet room tray myself as the last bathroom we had done the plumber did not make a good job of the installation. What make wet room tray can anyone recommend? I have a very good tiler to do the tiling just want to get the tray and prep work done properly.
Thanks again
Thanks again
If it's a wet room should there not be no tray? Are you putting in a shower tray and then tiling flush with that.
I'm doing a wet room myself at the moment and i don't have a shower tray. I will be tanking the whole room before the tiler comes and they will then use levelling compound to get his falls for the waste water drain.
Thanks had never heard or ever seen one of them before.
They seem more expensive than shower trays which is odd considering you need to get them tiled after fitting.
Hope it works out for you which ever brand you go for.
