Welding Squares
Limburger
31 May 2021
Netherlands
Hello,
I couldn't keep these to my self, had to share. I'm a mechanic and also work alot with metal. Now i'm building my ''dream'' workbench with a square tube frame. I saw on youtube that Jason from Fireball Tool makes squares for these jobs. To square things up to each other in both directions, were you normally would tag and check with a square and adjust as needed. No need witch these things.
Man I couldn't make this frame faster or better without these.
The tabs make sure the pieces line up.
Really can recommend them, they are located in the USA but also ship from Czech Republic, I believe from Strong Hand Europe (I bought their clambs also).
www.fireballeu.com EU
Fireball Tool US
Nice I’ve had these on the wish list for a while but not been able to justify them. Good to hear they’re worth keeping in the list.
never needed anything like that in 50 years.....
have a couple of those magnetic welders squares when needed to hold the 3rd thing when welding.....I work alone...
easy enough to alow for welding pull, well after years of practice....
First "thing" we made on a welding course 40 years ago was something quite like that! It's still lying around somewhere and comes in handy occasionally, if I can find it.
I also have them but they are always full of metal shavings. I bet when you use them you live it :D
Know what you mean I use the magnetic ones too, and they do get a bit furry.
Hi Fergie - I'm looking to get some kind of 90 degree clamps for a wheeling machine frame, and later for a Locost chassis (hopefully).
I've read about the magnets affecting the weld (it'll be MiG) - is that your experience? if so, do you think the weaker magnets would affect it less?
Thanks.
Funny op should show that image, when I did marine welding we made our own square blocks to hole joints
Now later in life I am doing much the same in my wood work, clamping set squares in place to hold joints square ....
How about simple non magnetic welders clamps ?
I bought a couple of these on ebay 2 years back and they are certainly robust.
Similar things, albeit smaller, are readily available.
Thanks.
A magnet will attract the arc, it will try to pull it towards it. I can’t see it affecting the strength of the weld but happy to stand corrected ! At the end of the day, it’s for a workbench, it’s not a nuclear reactor so it should be fine ! Magnetic clamps are rarely used in any fab shops I’ve ever been in, and if they have, they’re only really used for tacking up, they get removed before fully welding.
Stevep beat me to it. Fine to use just to tack stuff in place, then remove.
But you are better off using non magnetic and clamps.
You will be amazed the amount of crud the magnetic ones collect, and can actually be quite a pain to position as they try and pull somewhere you don't want. I have quite a few but can't remember the last time I used one.
Similar things, albeit smaller, are readily available.View attachment 192676
That looks great Sideways - I'd seen the ones posted by the OP but very expensive for me - it seems we can get similar to yours, 300mm for about £34 each on ebay.
I guess two is better than one for each joint (clamped inside and outside, where possible)?
Thanks!
For something like a bench you may not need to use clamps at all. If you have cut the parts nice and square then just hold them down on a bench using ordinary G clamps or whatever. Then put a tack at one end of the joint. Check it's square with an ordinary square. You can bend the tack slightly to fine tune it, then another tack at the other end of the joint to hold it and check again. If your bench is wood then just arrange the pieces so the bit you are going to weld is hanging off the edge.
You can apply the same principle to the whole thing.
Thanks Fergie. It's not a bench, but a wheeling machine (/English wheel) so alignment is pretty crucial. If top and bottom wheels don't align it won't work properly. Here's a pic of the kind of thing:
The main frame we're making is of 100 x 100 x 5mm square section; we bought the wheel and anvils, but also need to make the anvil adjustment mechanism. So quite a lot of work (for us)! We're doing a fair bit of watching on general frame welding and will definitely take on board your suggestions.
