Weather centre Christmas pressie
PowerTool
24 Jul 2005
Darlington
For my ex-wife - I though it would look nice in the pub :D
Start off with some lime,some weather guages from Axminster (thermometer,barometer,hygrometer) and loads of holesaws and forstner bits - none of which are the right size :(
So,use next size up holesaw to make a template
Use a collar and straight cutter on the router to make holes from the front,then drill smaller holes through from the back
Find a flush trimming bit that is long enough to go full depth
And rout out/clean up
Make sure the holes are the right size (too late if not..)
Sand,polish and add the guages.
Andrew
They look good as a set - thought I would like to have a go at making a set like that at some time - Rob
Hi andrew
They look great! And you have just given me a great idea for a christmas gift for the father-in-law (he already checks and records the daily rainfall where he lives so this would really suit him).
What is the minimum thickness of wood would I need to recess the gauges?
Steve
Thanks Steve - guages are just less than 20mm depth.
Come in three sizes,I used the largest ones (100mm diameter)
Andrew
