Not sure whether this should be in the hand tools section or buying advice. :? Anyway, up until now I've used the scary sharp method involving wet or dry sandpaper to hone my edges. However, I've become fed up with the finer grit papers tearing, the hassle of getting the stuff off the glass when the paper needs replacing, the stuff wearing out too quickly... and so on. So, I thought I'd plump for another option - waterstones or diamond stones.
An awful lot of people seem to be using water stones and this leads me to believe they're the better route to go down. Something must be right if all those people are using them. They seem to have the advantage over diamond stones of coming in finer grits allowing a better polish when honing. At least I think I'm right in believing that an 8000 waterstone is finer than a 1200 diamond stone. The drawback of waterstones is that you seemingly have to flatten them frequently - a drawback not shared by diamond stones.
Then there's the question of what grits of each I'd need. Obviously, I'd like to buy no more than what's needed to do the job. So in the case of waterstones would I get away with a 1000/8000 combination stone for honing after shaping with a grinder? Or would I need something in between - is the leap from 1000 to 8000 too much?
As for diamond stones would 600 and 1200 grit do the job for honing? Or are diamond stones best used only as a base with the final stages of honing done with diamond pastes?
Finally, which brands should I be thinking about? Are Norton's any good and although there's likely to be a trade off in quality against price are the cheapo offerings of Axminster worth a look?
Ps. I take it the bigger the dimensions of the stones the better if you're using a clumsy honing guide like me?
