Dissolve
Hi,
I've been using a combination waterstone for a while now and after trying scary sharpening and diamond stones I'm sticking with water stones. I've just acquired 3 new planes to add to my fleet so I'm going to sort out my sharpening rig. I don't have room for a grinder/tormek style jig so I'm going to need to stick with coarse stones as the first step.
Is 800 grit coarse enough to re-grind the bevel on a plane iron using a honing guide?
I've always found it difficult to get a mirror finish on the back of a plane iron using my 6000 grit water stone, I'm not looking to spend the earth, but would 8000 grit with a nagura stone be a good place to finish up polishing/honing?
If 800 is coarse enough to re-grind bevels how many stones would you place in between the two? Is 800, 1200, 4000, 8000 a good setup or should I look at less/more stones than that?
What are peoples thoughts on keeping the stones submerged in water? I like the idea of keeping the stones together on a board ready to go, but I know some people seem to insist they must all be kept submerged rather than letting them absorb water just before sharpening?
Any tips on keeping things less messy in the workshop? I know it's going to be more messy than other stones, but if I mount them all on a board (removeable) what materials would be best to make it from?
Thanks guys!
Thanks guys!
