Water based Clear Lacquer for Spraying
Tenson
12 Oct 2016
Kent, UK
Hi All,
I make speaker cabinets, mostly veneer on top of birch plywood. I'm thinking about getting an HVLP spray system to apply clear-coat and would value some recommendations for a water based product ideal for spraying?
Some products say 'can be sprayed' but I wonder if there are any designed specifically for it?
Thanks,
Simon
I use sayerlack clear water based lacquer which I buy from movac.
Their code is HNAF7210/6 (10% sheen 6litre, HNAF72/40/6 is 40% sheen etc).
you can apply coat on coat.
Very nice finish, we've done kitchens with it.
Sayerlack have a lot of options!!
I see they also offer AT99xx 'Finest Quality Clear Water Based Lacquer'. Any idea how this differs than the one you suggest?
They do coat-on-coat or base-coat / top-coat solutions.
What is the advantage of base-coat / top-coat? Is it going to give me a better looking finish or is it just harder wearing?
AT99xx - I dont, I shall have to ask the rep next time, perhaps its like tesco's finest; comes in a better wrapper :D
Base / top coat, has the advantage that the base coat has stearate in it and is easier to sand back / denib. Coat on coat will give you same looking finish and same hardness, just a bit more difficult in sanding back.
