I am making some flooring for my workshop from t&g chipboard with some thin strips of oak laminated to the top ( to match the appearance and thickness of some salvaged solid wood flooring I have down.
The oak is,about 5 mm thick and glued on in 50 mm wide strips with Titebond 2 and finished with boiled linseed oil. All was going well until I noticed it was bowing up at the edges. I assume this is due to the moisture warping the oak from the boiled linseed oil on the upper surface only.
I have been able to flatten it out with clamping over a small batten but wonder if anyone has any suggestions on how to avoid it happening if I make more ( which I will need to to cover the area) ?
Constructive (pun intended) advice appreciated, although I suspect I might give myself the advice from the old joke "if you want to get there, I would not be starting from here!".
Thank you.
Thank you.
