Charlie Woody
Thanks Jason, you have been very helpful.
Charlie Woody":3uhgrtel said:jasonB":3uhgrtel said:First you need to look at the right type of hinge, the blumotion ones are here
http://publications.blum.com/2013/catalogue/en/#/102/
I would say you want to allow a 2mm gap so carcase of 19mm less 2mm gap equals 17mm which from the table gives an edge distance of 6mm, as I said above do a test to be sure but the hinge adjustment should be enough to take out any small differences.
Don't know what your jig is like but any half decent one will have an adjustment for edge distance, if not just knock up something like this, the screws can be used to adjust the distance or just screw the batten on where you need it.
Thanks Jason.
Do I need to make any allowance for the thickness of the door?
What is the correct distance from the front of the carcase for the hinge mounting plates as I can't see that on the link (might be me as I find it difficult to not lose the place when I zoom in)?
