SOLD —-For sale a WARCO WM240 variable speed lathe plus loads of extras including WARCO bespoke stand(with fluid drain)
£1150.00
Collection only Stowmarket, Suffolk
Bought this is 2017 and have hardly used it, it is in pristine condition as I have spent more hours on routine care than turning. Originally bought to enhance some work I was producing on a wood lathe, however, I did not go forward with that project. The lathe has stood under covers, cared for but not used for some time now.
Checkout: The PDF Brochure on the WARCO website
https://www.warco.co.uk/metal-lathes/16 ... lathe.html
Two speed bands 50-10000 and 100-2000
Variable 50-2000 rpm
1.1Kw motor
Double V Bedway
120mm centre height (240 swing)
Distance between centres 400mm
Spindle Taper 3MT Tailstock 2MT
Spindle Bore 20mm
Includes :Fixed and travelling steadies, faceplate, 125mm 3 jaw self entering chuck, 125mm 4 jaw independent chuck, 3MT drive centre, 2MT drive centre.
All gears for threading (LH and RH), Touch up paints
Box of tools, Oil can, Cutting Fluid, Bedway oil and cutting fluid
3MT ER32 Collet holder. Loads of brand new cutting tools.
Can be fitted with DRO and Milling attachment from WARCO.
£1150.00
1.1Kw motor
Double V Bedway
Spindle Bore 20mm
