Want to fit replacement double glazed windows.
evildrome
11 Aug 2016
Paisley
Given the comedy prices I've seen quoted for windows, is it an idea to have someone come & measure up the windows, take those measurements, buy the windows myself and have someone fit them?
TBF, this was a long time ago, but a friend told me his company was getting £50 per window to fit replacement windows.
Which seems plausible.
There's guys round the corner from my unit that make windows. I'll get a deal off them and I have friends of friends that fit windows.
you might struggle to get somebody to do a survey.
window and door surveyors tend to get about 0.5% of the contract value -could be wrong but thats from memory
you could measure them yourself but your problem will be ensuring you have specified windows which will comply with current regulations
£50 a window was probably 25 years ago :giggle:
you might have friends who do installs but Im sure they would be able to provide the CERTASS / FENSA self certification for building regs if you buy the windows
Just mesure the brick to brick openings take of 5 or 10mm to give you a little wiggle room when fitting.
Fitting windows is incredibly easy unless there is compications like a bay, or particularly awkward access so you could just do it yourself.
The place you buy them from should have a disposal skip as part of the arrangement to get rid of the old ones.
The manufacturer should be making them in accordance with the ggf guidelines. It is unlikely their software will allow you to spec a window which doesn`t meet regs`s. usually a warning will pop up and if you do want one with no vents etc. you have to take responsibility for it.
I always spec egress/ easy clean hinges on everything and toughened glass, trickle vents are mandatory now.
You can get a building inspector to have a look instead of getting a Fensa installer or just don`t worry about it.
This is not legal advice.
When I built a house years ago I fitted my own. The company I brought them from measured up and supplied everything I needed to fit.
Installation:
Screw the outside windowsill to the frame
Put frame in the hole and centre up, square with packing and fix with hammer in fixings
Put the glazed unit into the frame and pack out - will pull the frame square.
Add the plastic bit - can't remember what its called now.
Cut and push in the rubber seal.
Silicone around the frame.
Although this was 20+ years ago.
In theory you would need a building control certificate for this.
A friend of mine did this against my advice , he took the measurements the guy quoted but got them made elsewhere at a cheaper price. They were delivered but they didn’t fit . The original guy that did the quote only did rough measurements and then if his quote was accepted he would come back and re measure to get the exact size ..no wonder it only took him ten minutes to measure the entire 3 storey , 5 bedroom house ..so be careful with others trades measurements.
Doors and windows have to be signed off now.
So it isn’t the cheapest thing to have done now.
I didn't know replacement wi dows needed to be signed off now. Are you sure?
If the person fitting them isn't FENSA registered you should go through building control, you fill in a few forms and they charge you £150+ depending on how many windows etc.
UPVC windows aren't born equal, so be careful who you buy them from. The composition of the PVC varies in quality and the lower quality is prone to yellowing - they mix titanium into it, as I understand it, the amount added (it's expensive) decides its resistance to UV rays.
Steel reinforcement is added - these vary between none, round rods and box sections of varying thickness, which again has an impact on the quality of the final product.
Personally I hate using friends or friends of friends to do jobs for me - I'd rather do it myself or employ someone independent.
As Ollie said above, they're easy to measure and fit yourself (if flat) - buy a tower, rent a cherry picker or get some scaffolding put up. You won't have a Fensa certificate, but unless you're planning on selling your home in the near future, who cares!
My dad replaced all the windows and doors in a rental a couple of months ago. Just used an online supplier, measured it all up and they supplied. Dad did all the fitting. It's not rocket science, mostly getting it square is the main thing (check your openings are square when you measure up).
Only problem he had was he was a bit heavy handed on fitting one of the panes of glass and broke it, but given he saved ~£1500 on getting someone to fit them it didn't really matter in the grand scheme of things.
Didn't realise you had to get a Fensa certificate. Seems like a con to me. I can understand building regs for the safety aspect but a door or window replacement? My current door is mostly hanging on by a thread and I intend to make my own door and frame, it will be far better, more secure and more efficient than what is currently there, the idea that i have to pay someone for a certificate seems crazy, when i could just leave the rubbish door there instead.
You don’t if your ‘repairing’ the door / frame / window. I often had to do ‘extensive’ repairs to doors / windows at my last house.
I spoke to building control and we concluded that there was no definition of what a repair was and it was totally acceptable that ‘over time’ a door frame may rot out become replaced and then say the door rot out and be again become fully replaced through repairs. They were happy that for some repairs it might require a frame to be removed and refitted, not requiring inspection.
I just kind of accelerated the repair schedule!
