It's walnut singular not plural, ie, a good source of firewood - or turning wood maybe.Hi, that one confused me.....isn't the tree dead?
I'd agree with that assesment. I have a customer who was gifted a Walnut tree for a birthday about 50 years ago but where it was planted meant that it was a threat to her property so she had it felled.Before getting too excited about the tree's potential it would be worth cross cutting near the base and having a look to see how much, if any, dark coloured heartwood it contains.
Forty years old isn't that mature and it may contain little or none which would be disappointing if you've spent money on any kit or a portable mill service, although I don't think it's just age that influences that, but it can be a bit random![]()
Are pens turned from branches, ie with pith, better than turned from larger sawn pieces?I have been turning recently some branch offcuts from trees of ours - pens I use 25mm square so can be turned from quite small diameter branches...
aah I see....It's walnut singular not plural, ie, a good source of firewood - or turning wood maybe.
Wow! Just watched a YT vid on it.....got me thinking!As you have a chainsaw:
https://www.ebay.co.uk/itm/32534273...XwgzqajSc-&var=&widget_ver=artemis&media=COPY
Bought one like it a few years back and it works very well.
Branches should be cut to length at least three times width and end sealed, that will be best for turning as there's probably too much reaction wood for stable planks.
Clear trunk I'd mill 2 inch slabs around 8ft long and put it in stick somewhere to dry. If you get 50% useable that's not bad going.
No idea but they seem to work!Are pens turned from branches, ie with pith, better than turned from larger sawn pieces?
