JungleJim":2gzc24iw said:
...seems to be the desired look that I am going for.
That's a good starting point, the next major consideration is what level of protection you'd like.
There's a checklist you can go through to help narrow down finishing choices, with the first two (in this order usually, but not always) being how you want the thing to look and the level of protection desired. Next are the application method you'd prefer, what maintenance schedule you'll accept and last but not least what you can afford and/or get easily. You can also throw in preferred drying times in there if you like.
I will try it out on some offcuts first but was after some suggestions on how you would go about applying it, ie how many coats and and sanding between coats etc.
If you decide to go with the Liberon stuff there's a surprising amount of possible variation in how you might go about applying it, depending again to some extent on the look you're going for and the level of protection you're after.
If you like the natural appearance of walnut you can just wipe in, wait a bit, wipe dry, rinse and repeat until you're happy.
For a partially filled look you can wet-sand the finish into the wood, then carefully wipe off (or squeegee off) across the grain to leave most of the wood/finish slurry in the grain, possibly a light sanding of the surface after waiting a suitable time for the slurry to harden off (often more than overnight), followed by continuing to oil as normal after that, with one, two or more coats.
As a general thing you don't need to sand between coats of any penetrating finish, and in fact doing so can be counterproductive (but sometimes it is necessary to lightly abrade the surface for best results). The product instructions say to lightly rub with 0000 steel wool between coats, which is a good gentler approach that won't see you taking a half step backwards as some sanding routines do. Liberon recommend a minimum of three coats.
