Andymaker":2251svqb said:
...the late reads Machine: pk1380 test:39842 which from wallaces website I make a 1952.
I saw that one on ePay earlier this year.
The serial number looks to be overstamped. I read it as PK 1390 (looks like the 9 is over the top of an 8 ).
*The bearings in the sliding table. A couple of the bearings are definatly gone. The table seems to bump into a few of them instead of gliding over them. I asume the way to adjust the height of these bearings is by turning the large slot screws ajusts them via a cam?...
I had one bearing on the table missing completely, along with the eccentric bolt. Replacement bearings weren't too costly (about $NZ20 each IIRC). I know a guy with a machine shop who made me a replacement eccentric bolt. He's very good - and expensive (cost me $NZ150, ~£75).
Yes the bearings are adjusted by turning the bolt, which is eccentric - effectively a cam. The bolt is locked by the nut, but also by a large grub screw from underneath. I was worried that the grub screws would scour the bolt shafts (if you look carefully you can see scour marks on the left-hand bolt in the pictures above). I attempted to hacksaw and file some brass slugs to go between the screw and the bolt...
... but in the end an Aussie on the Canadian forum turned up some finer slugs for me.
There are also 6 rollers controlling sideways play (no fancy roller bearings here!).
About this time I was offered a 1928, 1 ton, 30" bandsaw (with 1 day to remove it before the building was demolished) and the PK had to go into storage (where it still is). So I still haven't set up the sliding table. My intention was to set up the four outer rollers so that the table was level with the fixed table, and then adjust the intermediate rollers until they firmly touched (but not lifted) the sliding table.
Note: My PK is an earlier model, and detail may differ - especially with regard to the grub screws.
Cheers, Vann.
Disclaimer: No Photobuckets were harmed in the posting of pictures in this post.
