Hi,
Any advice on how to adjust the infeed, outfeed, chip and pressure bars on wadkin 12x7? Can they be adjusted at all? It's been driving me nuts. I have just replaced the cutterblock with a replacement. All that supports the chip and pressure bars are pins that locate into the side of the blocks that holds the infeed and/or outfeed roller, these have no visible means of adjustment. The blocks themselves sit on solid collar type washers, again, no visible means of adjustment. the only change that i can make is increasing or decreasing the pressure by tightening the nuts on the bolts encased in springs which hold down the infeed outfeed rollers and pressure bars.
I hope I'm making sense to anyone who knows these machines. What's driving me nuts is the diagram in the manual showing the heights the above should be in relation to the cutting arc. HOW!
Thanks Jo
Thanks Jo
