9fingers
Good Surname or what ?":3p68lafn said:Paul,
Comparing with Misterfish's and Katellwood's I'm pretty sure mine should mount on the parallelogram arrangement like theirs. The blocked hole is circled in red and on close inspection the metal in the hole is slightly proud and has threads. Looks as though it was broken off.
thanks
Phil
Phil, If you can use a small grinding disc in a Dremel to cut a slot across the diameter of the bolt, you should be able to get it out with a screwdriver. Don't worry if the slot also cuts into the main metal a bit, that will still be plenty strong enough.
If that fails, drilling a hole in the stud and using a screw extractor ( a sort of coarse, left hand threaded tap) should have it out.
Can you tell us if you are proposing to buy replacement parts via the NetBlind Paul approach or want to make your own parts from stock steel?
Bob
