Wadkin ags 10 Lock Nut
I was thinking along the lines of obtaining a length of suitable threaded bar and matching nut, available from the people mentioned previously.
You could then let the threaded bar into the end of the spindle in place of the existing one.
If Deema made the shaft then he will be well placed to comment on whether that is a viable option.
There should be a threaded hole in the end of the shaft to allow it to be extended, this can be used with a collar / bush to create an alternative nut arrangement.
Here is a question, asked with complete naivety :unsure: - Could a nut not be cast around the threaded spindle? Maybe some form of reinforced epoxy or even bronze?
But surely bronze would be okay?
You would need to be well sure the cast nut could be removed from the spindle once it had solidified. It will be intimate contact with the shaft when poured and as it shrinks when it cools, it might become even more tight.
With a slight modification, you could do a lower risk version of this: make a cast of the threads on the spindle in wax or foam, remove that and then use in a traditional casting mould to make the bronze casting.
The threads in the cast nut would almost certainly need some hand finishing and that would be very tricky.
Maybe at the wax stage, you could scrape out a little material from the soft wax to give clearance.
It would be great if there were something you could apply to the existing threads that made them uniformly bigger in all directions so that the wax casting would have clearance without any need for adjustment.
A traditional solution to repairing the shafts of motors (often when the keyway has been wallowed out) is to turn them down a little, weld them back up oversize and then machine a new keyway.
A similar approach could be adopted here: turn off the old threads, weld back up, turn down to 16mm diameter and then cut an M16 x 2 LH thread on the shaft. The secret in the initial diameter reduction is to go below the root diameter of the new M16 thread, so that the new thread is cut into fresh weld material, not some unknown alloy of old and new material in a heat affected zone.
I can’t remember the details but there have been previous posts on this exact same thing, a new nut for a Wadkin AGS. I don’t think anyone found a supplier of an after market nut that would fit. A good search on these forums may find the posts.
Interesting thread ( no pun intended ) sad thing is there is some old boy somewhere who probably has a few of these nuts in his shed or garage just sitting there . Hopefully the op will be able to source one or come up with an alternative option.
Good reading in many old engineering books, in the days when parts were expensive and labour relatively cheap.
There are still companies about who do metal spraying, electro deposition and the various other techniques, all very expensive nowadays.
Practically speaking I would have thought the easiest and cheapest approach would be to get a suitable length of left hand acme threaded bar and a matching nut in a generally available size, maybe M16. Then fit the bar into the shaft in place of the original. Many ways to do that. Saves an awful lot of faffing about.
Hi fellas! First time posting here!
Been slowly restoring this wadkin ags 10 saw and now got too actually putting a blade on it.
Trouble is I have absolutely no idea what thread this is or where to get one. I know for sure it is a reverse thread. Suspect it is imperial and also suspect it is square not acme.
Can anyone help with sourcing or identifying this thread or how to get a nut for it?
I have already messaged my local machine shop and they were very helpful quoting me websites where I may find a nut for it (but I have no idea which one is the right one) but they said the quote would be around £300-400 as they don't have the skills and tools so would have to take a whole day to do it.
Thanks Sam!
https://www.advancedmachinery.co.uk/machinery/product.asp?item=main-spindle-nut-special-7725-230
Holy smoke thank you soo much. I'm not 100% sure that is the right nut. But it was under the wadkin 10 ags section and I'm hoping special means that it's the funny square threading. There was only 1 left in stock so I've bought it up scared that it'll be gone by the time Customer service has replied. I'm either going to be £90 down but a working table saw up or £90 down and a useless nut in hand.
