• If you have bought, sold or gained information from our Classifieds, please donate to UK Workshop and give back.
    You can become a Supporting Member or just click here to donate.
For Sale Vicmarc Outboard Bowl Turning Attachment
TSH
New member
25 Nov 2022
Wolverhampton
Vicmarc Outboard Bowl Turning Attachment.
Brand new - never used (the images are stock photos).
£300 ono. I can pack and send to any UK address.
Details from Vicmarc website...
The Vicmarc Outboard turning attachment is designed to facilitate large diameter turning and is mounted to the outboard end of the lathe. It will fit onto any of our large Vicmarc Lathes such as the VL200, VL240 and VL300. This unit can also be mounted onto other brand lathes providing the headstock end of the bench or stand is flat.
The Outboard Turning Attachment has a 40mm diameter support post that is locked in place with adjustable locking levers.
This has been designed to be very rigid and is made from solid steel and cast iron. A swan neck design has been incorporated to increase access to the work piece. They’re also adjustable in height due to the extension pipe located at the bottom.
For your own safety, the maximum recommended weight to be used on the outboard side of the machine is 50kg.
33kg Net Weight
    53.8 KB
    143.2 KB
    30.7 KB
