Wend
Hi all,
I have a Paramo No 50 vice, and every half rotation of the handle there is increased resistance, and then a click. I can't see anything that would cause it, so I imagine that there's something inside the main body of the vice, with the quick release mechanism etc.
I believe that if I remove the bent piece of metal at the right end of the screw in the picture below, then I would be able to fully remove the screw and poke something into the hole, hopefully clearing the problem. However, would it then be easy to reassemble the vice without removing it from the bench? Having finally got the jaws planed just right, I'd rather not have to take it off again if I don't have to!
Wend
Wend
