bugger now it seems that a) I can't remember the thread and b) you're too far away. Sorry about that.Woody Alan":2odkxupd said:
FatFreddysCat":1o1f6f2s said:Edit: Just took a quick look on eBay. There's someone there doing the proper spiked feet (the sort you are supposed to use for "accoustic decoupling" at around £3/pr. Auction number 110396507714 (URL won't work in link :evil: ). They're probably your best bet
FatFreddysCat":c0ekwl5v said:The edges will need to be sanded and the main thing I'd be concerned about for a beginner would be dubbing-over the edges. In my trade we often make-up sanding boards by contact-glueing aluminium oxide sanding roll onto 12 to 18mm MDF (circa 80 x 250mm works well) and if needs be an offcut of 2 x 2 PAR can be attached along one long edge to make-up a right angle sanding board with fence. That should keep your edges square and prevent dubbing over.
Ooops, no I meant something like the Ixos Superspikes I have on my own HiFi. I've just asked the missus and she actually got them from a firm just down the road called Audiovisual in BacupDaveL":2718i61b said:Do you mean these, sold by a camping retailler?
Not sure I've explained things too good. Flat piece of MDF 80 to 100 mm wide (because sanding roll is 4in or so wide) by 200 mm or so long. Actual size no really that important. Rip off a piece of sanding paper and apply contact adhesive to one side of MDF and to back of sanding paper. Let glue go off for 10 to 15 minutes. Stick together. That's a basic sanding stick, although we normally make them two sided - 60g and 100g or 100g and 150g. If you take a sanding stick and screw a piece of 2 x 2 PAR to one face parallel to the long edge (makes a sort of "L" cross section) you've go a sanding stick with a right angle fence. We use these a lot because of the need to sand off stuff quickly but without dubbing over. They don't last too long (a week or so, often less), but as they're made from offcuts it doesn't matter too mucgmattyd":2718i61b said:Ah, I think I know what you mean - By making a guide of two peaces of MDF at a 90 right angle with attached sand paper I can maintain a clean sanded corners and sides?
wizer":l9gulkfp said:Circular Saw. The Jigsaw will leave a worse edge than the CS. If you use a saw board then you will have minimal chip out on the face side. To minimise it even more you could add a good quality freud blade and also cover the cut line with masking tape.
Circular saw. Not only is it more powerful, but even the poorest circular saw can normally do a better job than a jigsaw. Most jigsaw blades have a tendency to cut off square when dealing with thick solid stock, even the Festool and Bosch jiggers with the extra blade clamp aren't completely immune from this "feature".mattyd":xmnfh760 said:With regard to cutting the worktop (which is 40mm thick) would it be better to use a circular saw or a jigsaw.
