I have a record Coronet Regent lathe that is 10 months old which I haven't used for 5 months, workshop too cold. last week I moved it to a new workshop and spent a lot of time getting the bed level as the concrete floor has a slope. It was level when I finished with the headstock feet being a good 3 cm higher than the tailstock feet. However given the size of the bed I think that there is unlikely to be any significant deflection in the bed. This morning I decided to do the final alignment and found a vertical separation between centre points of 3mm. I am pretty sure that this was not present prior to moving the lath but it's 10 months since it was last set up when the centres were perfectly aligned. I am at a bit of a loss as to how this has happened and am wondering if I drop the headstock end will it pull everything into alignment, I would have thought that unlikely with such a heavy cast iron bed. The bases of the headstock and tailstock are clean.
Any suggestions?
Any suggestions?
