Doug B
Shy Tot
After reading Michelle K’s post about making blades I thought I’d post up some photos of some blades I made a while ago to use in my Veritas Jack & smoother planes.
The steel the blades are made from is gauge plate bought from Cromwell tools, the blue label if you can zoom in gives info on hardening, tempering & the steels composition.
First up the blanks were cut to rough size then squared up at the miller
The blades locating holes were then milled
Finally the finished shape cut.
The blades were then suspended in a biscuit tin surrounded with BBQ coals with a paint stripper gun blowing hot air into the lit coals, the blades were held at cherry red for 15 minutes.
next the fun bit the red hot blades were then quenched by lowering into tin cans containing used motor oil, as you can see it bursts into flame & the oil boils out hence the tins being in another biscuit tin & that being on a board
This process leaves the blade hardened & covered in a black residue which needs removing (far right blade) once removed the blades were tempered in the oven following the instructions on the gauge plate label depending on the hardness you want, these were held around 200 degree for 15 minutes then allowed to cool with the oven & removed from the oven when completely cold.
The middle blade is a finished blade the left hand one an original Veritas used as a pattern
Finally the moment of truth, the blades work very well & I’ve been very happy with their performance
I’d just add that these blades were made solely for my use, hope it’s of interest.
