Paul Chapman
Until now my only spokeshaves have been the Record A151 and A151R. I've had them for years and they are probably the two tools I dislike most. The problem with them is that they are so crudely made, with such poor blade seatings, that they chatter - no matter how tight I do them up. I've tried flattening the blade bed but it's very awkward to file. Not to put too finer point on it, I hate using them.
Anyway, a few weeks ago I was in a second-hand shop and I saw a Veritas low-angle spokeshave that had never been used and it was going for £6 :shock: :shock: Alf did one of her excellent reviews on it here https://www.ukworkshop.co.uk/forums/view ... hp?p=36032 so I won't bother repeating what she said, but just give you my impressions.
First, it's very well made - a real precision tool like all Veritas stuff. The blade is very small so I treated myself to a Veritas small blade holder. It's very easy to hone the blade with this clamped in my Eclipse honing guide and because the honed edge and opposite edge of the blade are parallel, it's easy to flip it out of the blade holder to wipe off the wire edge and to replace the blade in exactly the same position. The back of the blade was very flat and required no work on it.
In use it's really nice, once you get the hang of it - which doesn't take long. I particular I like the fact that you can adjust both the blade depth and the width of the mouth - an important feature I think when doing precision work on small pieces.
Setting it up is a bit of a fiddle at first - but quick once you know how. You can reverse the toe piece so that the same shave can be used on concave and convex pieces. However, rather than do that I will keep my eyes open for a second one and keep them set up for the two types of work.
Overall, a cracking little tool - highly recommended
Cheers :wink:
Paul
Cheers :wink:
Paul
