Vormulac
Hi folks,
I received my cambered roller for the wonderful Veritas MK2 the other day and encountered something a bit odd. The threaded hole into which the brass bolt is screwed was not only internally coated with the black powder coat or whatever it is that protects the main body, but it also tapered (or the coating thickened towards the bottom). Basically this meant that I was unable to screw the bolt down far enough into the body to make it grip the shared 'upper' part, the bit that holds the blade.
Naturally my tap and die set didn't have the right piece to bore it out, so it was down to about an hour of carefully winding the brass bolt in and out, hoping that it would wear away the coating/aluminium before the bolt itself sheared off.
It worked eventually and as a guide it works as brilliantly as I expected, but I was very surprised that this unit appeared to have been so poorly finished or checked, from a company that to me embodies quality and careful manufacturing process.
Has anyone else found this with their cambered barrel assembly?
V.
V.
