veritas dowel cutter
sniks7
15 May 2008
Winchester, Hants
Has anyone used one of these? Do they work well?
And another thing.. I'm trying to find advice on what sort of hand plane to get. I really just need it to finish some hardwood shelving.
It would be handy if the blade could be used for opening paint cans and if it's large and heavy I could use it as a door-stop, because that's about my level of woodworking skill..
I see axminster do a couple for thirty quid of so. Worth it? I'm not particularly bothered by price, but I don't really want to spend a fortune on stuff I haven't got the experience to use.
Yes, they work brilliantly. Very satisfying to use too! Once you have your stock prepared, you can make dowel at a rate of about 3m a minute... If you want very long stuff you'll have to be careful about whipping on the exit side - you can make an extra support for the dowel to go into, or just support it with your spare hand.
Cheers,
Neil
Squared up to approx 1/16" over the size of the dowel. Obviously it has to be straight if you want a straight dowel.
Cheers,
Neil
I will second that, these are brilliant.
They make very nice dowel which being from the same stock as the rest of the project is a perfect match. 8)
