Veneering question.
Steliz
Camberwell Carrot
11 Dec 2017
Hungary
A friend has asked me to smarten up an L shaped bench seat that fits around a brick wood burner. It is made of pine and has been coated with something non penetrating. It is in a bit of a state as the fixings had to be drilled out and the various parts are not flat.
Initially, I was just thinking of squaring it all up and gluing it together, repairing the holes and give it back but she has some Oak furniture and I thought I might have a go at veneering it as well. After some further thought I decided that making the whole thing from new with plywood would probably be easier.
I have the means to resaw some wood down to a couple of mm but my Oak stock consists of various sized off cuts so it will be a bit patchy. My plan is to run the Oak over the planer, resaw a slice on the bandsaw and then repeat until I have enough. I will then glue it on smooth side down and sand to a finish. The tricky part will be the rounded corner and I think I will glue in a block of Oak rather than try to bend a veneer around it.
I've never done any veneering so I would appreciate any useful tips anyone has.
    248.1 KB
That project poses several challenges.First you have to be sure the coating has been removed to the extent that successfully gluing veneer will be feasible.The location by a strong source of heat isn't exactly ideal either.Resawing to produce veneer can be a great way to produce something a lot more forgiving than the standard 0.6mm furniture veneer.It is also quite challenging to get wide sections suitable for the job.Having produced them you really need to apply a balance to the decorative veneer,not just because its good practice,but the proximity of strong heat will greatly increase the likelihood of something moving.
