thanks thats the one i thought from what you said about darker and lighter.....
45cm tall, 25cm deep. 23cm wide
next step gluing the mitre joints there about 25cm wide.... i have biscuit them 2 in each side to make things easier..... 4 sides to the box... i do not have the corner claps
i guess that tape trick may not be good as the mdf veneer is alot wider than i see most people going that on.....
there will be back that goes inside.... and the front goes on the outside... before gluing maybe also good idea to have the back in rather than adding it later?
for the not quite perfect edges i guess there may be odd gap/hole/tear out what would be good ways to fill them... i may stain i have not got around to testing yet. also the corners might be sharp can i still break them with bit sand paper or may that not work as its mitred veneer
