I've decided to make a little Clock like the one below, where the body will be Burr Elm Veneer and the top/bottom mouldings are from some other Elm which has a very special grain. It's nothing fancy but will use up some offcuts
I started by dampening the veneer which was quite curly, then pressed it between some sheets of glass covered by some old wall paper cut to size to soak up the dampness. This made them nice and flat and easy to cut, they are very small.
I cut some in pairs and taped them together ready to be stuck to the substraight, MDF or maybe solid timber! They were originally sequencial but got mixed up so matching them perfectly is no longer an option " for the eagle eyed"!!
And this is some of the Elm to be used for the top and bottom moulding. the profiles will be different.
The clock insert still has to be purchased and is is about 90mm dia, any good places to buy one appreciated.
I'll post picks as I go along as that seems to be what everyone likes to see rather than the finished article only.
