A
Anonymous
Guest
Hello everyone,
This is my first post. It's a great woodworking information resource you have here!
I'm building a pair of large loudspeakers and plan to veneer them with 0.6mm quilted maple using the PVA and iron method. The carcass is solidly constructed from two18mm sheets MDF laminated together and glued + screwed so it won't be coming apart anytime soon. As I said, these are quite large: approx 1m high x 400mm deep x 260mm wide. The look is blatantly ripped off from these:
http://www.avalonacoustics.com/opus-grand.html
I've used paper-backed veneer before but this is the first time I've tried using the raw stuff. I've attached a picture of the veneer - will this be flat enough to work with? I applied some PVA to a couple of scraps and the veneer curls-up within a couple of minutes...
Any other tips or advice is very, very welcome!
Regards,
David.
Regards,
David.
