tekno.mage
I'm surprised that your eletronic variable speed lathe came up to 3200 revs quickly enough for you not to notice before harm was done. One of the things I find extremely annoying about some of the modern lathes is the time they take to both come up to speed and also to run down and stop. The old Vicmarc which I also use is much more user friendly - it comes up to speed fairly quickly (ie not so slowly as to be annoying) and runs down at a sensible rate plus allowing you to grab the handwheel and slow it down even quicker if required (ie the hand wheel doesn't fight back as it does on the modern Record Power and Axminster lathes I've used). I know - I could probably re-programme the inverters to correct this but life's too short to read the 300 page manual written in poorly translated english to find out what parameters to change and how to do it!
