Hi,
I have a sectioned built garage that has corrogated cement fibreboard sheets for the roof which I thought was leaking, however I'm not so sure it actually is?
I insulated and boarded the full garage out quite a few years ago, however a few years back I noticed the floor was wet after long periods of rain, I also emptied about a third of a bucket of water (still not sure how that happened as I'm sure it was a sealed unit) and last year I removed the ply and Celotex to see if I could find out where the water was getting in, and of course it's been bone dry!
It's not that big of a garage and I'm sick of tripping over the boards so I have decided to put them back on after I reinstall the Celotex, however I wonder whether the water was caused by not originally adding a vapour barrier?
I initially built a 2 x 2 frame for the Celotex, however there was still a 2-3 inch air gap between the roof and Celotex, also the underside of the fibreboards, which I gave a coat of bitumen on them.
Could the reason for the ingress of water be due to not having initially adding a vapour barrier of some kind?
Any opinions/thoughts would be appreciated.
