skipdiver
Related to my other post on insulation, i've decided to put omnifit earthwool batts in my rafters and leave a 2 inch air gap above as per Knauf recommendations. They also recommend to fit insulated plasterboard beneath this to bring up the u value but i'm not concerned with that as it is only a workshop. Their diagram doesn't show a vapour check barrier but i imagine the insulated boarding will be doing that role. So do peeps think i should polythene sheet over the rafters before i board them with OSB or not, given it's not a habitable space like a house. I'm buying some polythene anyway to put under the floating floor, so i will have some but there are conflicting ideas about their use on the net, regarding where they are in a building, what the building is used for, and the local climate. What's the prevailing opinion; have you done it or left it out?
Cheers.
Cheers.
