Vaneering with pva
When you use contact adhesive it does what it says on the tin.......adheres as soon as it makes contact
At least with pva you have some time to re-position your veneer if need be, although you should leave for a few minutes
before applying the veneer.
Davon
Davon
And with hide glue, if you muck it up, you just locally reheat, nudge into position.
