I want to make some vacuum bags up. I have no idea what sizes I need, so was going to do a couple of semi disposable ones from http://www.ecfibreglasssupplies.co.uk/p ... -tube.aspx
what does the handling and safety statement mean?
How do I seal the ends?- something like http://www.ecfibreglasssupplies.co.uk/p ... -tape.aspx
or could i use 2 of the waste pipe idea, one on each end:
"To close the open end of the bag I made a closing system out of 2 pieces of waste pipe one 30mm one 40 mm 1.2m long. I cut approx 1/3 of the off the 40mm pipe all the way down its length. To seal the bag wrap the open end round the 30mm pipe once and then clip the open 40mm over the top of the 30mm pipe to make the seal"
from step-by-step-guide-to-building-your-own-vacuum-bag-press-sys-t59509.html
