Hi,
Has anyone on this forum used Water Clear Polyester Casting Resin as a decorative filler?
I have a lovely 40mm elm burr board and it has a 4" dia hole going right through It, I would like to plug the hole with a clear resin. Once the resin has set, how do I finish the resin? As I'd like the finish to be clear, so you can see through the hole.
Any advice would be appreciated
