A
Anonymous
Guest
Hi all,
I want to make a router table using my 1/4" plunge router.
Here's how I plan to go about it, I think it sounds about right:
1, Remove existing baseplate from the router and mount an new, larger rectangular plate of MDF thick enough to prevent sag. Make a hole in this plate to allow cutters to pass through it.
2, Make a hole in the table top to receive the plate, of the same depth as the thickness of the MDF (so the plate lies flush with the table top) with a smaller "ledge" to support the plate.
3, Mount and fasten the plate in this hole with the router suspended under the table top.
The result I hope for is a smooth table surface with a hole to admit the cutter.
Two questions - firstly, this method seems to agree with most of the info I've found on the subject of making a router table. Does anybody have any more comments or advice?
Secondly, my router is switched on and off by a standard spring-loaded switch on the router body (on when depressed, off when released). How then can I operate it when it's mounted in the router table? Surely I can't keep one hand under the table holding the switch down, and holding it down with tape or a clamp doesn't sound too clever either! :?
Grateful for your advice
