Droogs
Not the Sharpest Moderator in the box
The set on the saw teeth was too wide and the machine was trying to create too large a kerf. Also the drill may have had a low battery or just was not powerful enough for the type and thickness of wood. Or as a beginner you were applying too much downward pressure. When using a saw of any kind you are meant to let the saw do the work and it's own weight will make it go down.
So to me it appears to be and in no way to denigrate you the type of error seen in the IT industry everyday known as an EBCAD system failure. Error Between Chair And Desk.
Possibly an expensive lesson but one I am sure you will learn from and always remember. Don't force the tool ever, let it just do it's thing. If it takes time then it takes time. Also on holes that size it is best to use a static drill on a stand or a pillar drill.
edit typos
edit typos
