garethharvey
I have been using some MDF templates to cut some 20mm hardwood in my table router. I have been using a flush trimmer with a top bearing. The hardwood has been cut approx. 2mm wider than the template.
The issue I have is starting the piece in the table router, quite often it just grabs the wood and rips a bit out. When it does work it's great, no further issues.
I have tried approaching the cutter very slowly but just can't overcome this issue
