RogerS
Still don;t buy that. If you set the knives level with the outfeed table then it will still cut.
RogerS":18dp9hjb said:Fascinating when you start thinking a bit more about what is an everyday task!
Point of info..the Sedgwick has three blades.
Steve Maskery":16fn7qbb said:You said it yourself earlier. Snipe when surface planing is when the knives are too high WRT the outfeed table. The workpiece drops off the infeed table and into the cutter head. The solution is to raise the OF table so that it supports the workpiece in line with the fresh cut surface (or lower the knives to effect same).
S
