Mike.C
I have just helped a neighbour set up her laptop with a new ISP and when we played the instruction cd it asked which cable she wanted to use to connect to the BT Homehub/internet, and its recommendation was to use the Ethernet cable because it claimed this is much faster then USB2.
Is this correct, because I always believed that USB2 was the fastest connection? We have connected the Ethernet cable for now.
One thing we did notice (which may have nothing to do with the Ethernet cable) was that her keys are very slow to react, and the letters take a faction of a second longer to appear on the screen. If for instance you type A B C D E, the letter A will appear just after you have typed B and the letter B just after you type C, does that make sense.
TIA
Mike
TIA
Mike
