Uploading images.
filsgreen
21 Feb 2006
Litherland, Merseyside
I'm having a problem uploading images to the forum. I'm copying the picture from Snapfish but I can't paste the image because "paste" is greyed out. Any ideas please?
Phil
Thanks to Adam I found out where I was going wrong :D No still not got it. I've copied the address from the properties page but the image doesn't come up only the web address.
Roger, I put the ignore request in after 14 views!
I am victiim no 41 where is the "ignore" message :lol:
Is this some form of test?
Cheers :D
Tony
Edit: If you are still having problems check that the link to your post follows the format below:
Code:
[IMG]http://i298.photobucket.com/albums/mm256/TonyWarrington/phew2.gif[/IMG]
this should display a picture
and it does!! :)
Filsgreen, did you figure it out or not?
Why don't you put your images on Photobucket.com? They actually make it easy to add photos to your forum posts by giving you the IMG taged link to copy. Actually you just click on the tag and it is copied to the clipboard. All you have to do is paste it into your forum post.
