minilathe22
For the motor you want a 4 pole or 6 pole if you like doing larger items as it runs slower. Although you can make any motor run at almost any rpm with a vfd, the more poles it has the more torque it will have at lower speeds. If you are going through all the effort of swapping the motor then its worth getting one that is at least 1HP, more than 2HP the motor is probably too physically big to fit in the hump unless you lower the motor bracket somehow. The motor I have is an ABB 6 pole I got on ebay as a used item, I believe new these are around £400, new TEC motors of similar spec are around £150 on ebay. Probably a premium ABB motor is overkill for a hobby wood lathe. With secondhand motors some are dual voltage rated, but some older ones do not mention 240v at all, I would hesitate to purchase a motor that is rated high voltage only as it may not be easy to get it working on 240v.
As mentioned by several people before make sure your VFD can handle the current rating of the motor with room to spare, don't just use the power rating. The VFD I have is a Yaskawa CIMR-JCBA001010BAA. Be careful purchasing a VFD, many are 3 phase to 3 phase converters, which is probably not alot of use! you want to check its a single phase to 3 phase type. The ABB motor I have is M3AA90L-6. It is possible to fit the VFD below the motor so its all contained in the lathe, but then adjusting the settings is difficult! I opted to put the VFD in an old PC case where it can get lots of ventilation and protected a bit from dust. There are much cheaper VFDs online, many people have used them but usually complain about the quality of the manual/support.
