Wuffles":2t23qjzk said:Go on, anyone recognise this quote? "Have we got a video Rick?"
The video was posted ages ago Lonsdale73.
Lonsdale73":83wr37n9 said:Wuffles":83wr37n9 said:Go on, anyone recognise this quote? "Have we got a video Rick?"
The Young Ones, featuring the Damned performing "Nasty" and Alexei Sayle posing as a driving instructor from Johannesburg
DiscoStu":k6k638bp said:I'm very much resisting the guide bushes for my Triton. The main reason being is that my Triton really is for the table and I am intending to go for a Festool router for handheld use. So I'll get a guide bush for that. I do like the router option for its speed and accuracy (vertical holes will be quick and easy). I do however like Peters system as it packs away nice and small and I can see me using it more easily on odd one off jobs.
Petey83":ebl4kn2i said:DiscoStu":ebl4kn2i said:I'm very much resisting the guide bushes for my Triton. The main reason being is that my Triton really is for the table and I am intending to go for a Festool router for handheld use. So I'll get a guide bush for that. I do like the router option for its speed and accuracy (vertical holes will be quick and easy). I do however like Peters system as it packs away nice and small and I can see me using it more easily on odd one off jobs.
i use those exact guide bushes on my Festool OF 1010 and OF1400 - just needed the right Leigh adapter plates. All in for the 2 plates and the adapters i paid about £70 - £75.
Not trying to put you off buying Peter's system as i do think it looks nice and as mentioned the extras he has planned may increase its versatility.
Yeah some people do use the 32 holed rails to make the tops with a 20mm cutter and router.woodbrains":202xteky said:Hello,
Thanks, standard carcasses have 32 mm spacing for shelf pins etc, so there is logic here. Actually, my tracksaw is a Bosch and the rails can be bought with 32mm hole spaces. Might be possible to make a table using those.
Mike.
gidon":2ddkd3nl said:I think it's a clever system and would come into its own if you wanted to make lots of tables with these holes.
But for a one off it's quite expensive and looks quite a faff to me when you can get a ready made MFT top for less than half the price (and that uncludes the quality bit of MDF ):
http://www.powertool-supplies.co.uk/fes ... GwodXFgK9w
I bought one of these (tops) but ended up getting an MFT - I use the MFT all the time - the hole system is handy but it's for cross cutting and routing that I use it for all the time.
Gidon
Petey83":7jvgnhd7 said:gidon":7jvgnhd7 said:I think it's a clever system and would come into its own if you wanted to make lots of tables with these holes.
Gidon
this is not the top for an MFT3 though it it.... :?
woodbrains":278ouxht said:Thinking about the Parf method of doing the holes, with sticks and bushes, I think there is potential for this to be even more accurate than a CNC produced template. Although the template will be very accurate in itself, the router guide bush would have to be super accurately concentric with the router bit, or errors could creep in. It could be mitigated by making sure the router is orientated the same way for each hole, but forget and turn the router a bit, and there will be errors.
