Dabur
Hi,
I am very new to the world of scroll sawing (and woodworking in general). I borrowed my father’s scroll saw a couple of months ago for a small project I was working on, since then I have been looking into what you can make with a scroll saw, and I am amazed at what can be done with it, very versatile tool, wish I got one years ago!
I am currently working on a pattern for cutting out a portrait of a tiger (not sure if there is different terminology for that type of work). There will be some very intricate cuts involved so hopefully I am not pushing myself to fast. But what type of wood should I use? I have been practising on 6mm plywood, but should I cut the main piece out of plywood? I do not know too much about the various types of wood. Would plywood be considered a “cheap” wood to use? Ultimately it would be nice to be able to sell some pieces if the finish is good enough, but I am not sure if people would consider buying something cut from plywood? What wood have others used for a similar project? Also any suggestions available on what thickness of wood be ideal for this type of project? Ultimately I will want to stack the wood so I am cutting out more than one copy at the same time so I guess the wood should not be too thick. Is there any ideal thickness for this type of project or does it just come down to personal preference?
Thanks in advance for any advice
