DigitalM
I'm not entirely sure why, as it has been left on the machine and not abused, but my KITY planer fence has developed a slight twist. I'd been getting frustrating results when trying to true up against the fence, having already flattened on the bed. There's not much in it, but obviously it's not good. Has anyone else had this? How would I got about correcting it?
The measurements I've put in the photo are made up but to give you an idea what is wrong. It's probably about 2mm of rocking that I get when I place it flat on the planer bed and gently rock it - hence the figure I quoted - I haven't gone at it with feeler gauges or anything yet.
EDIT: I went carefully over the planer bed (which I was using as reference when checking twist) with a straight edge to check that was true, which it is. I also ran a mitutoyo dial indicator across the lower bed, to check that it was planar with the upper bed, and it is within 0.02mm across the width - I suspect that is good enough but haven't seen any figures quoted.
